Author Topic: Nasty grinding type nose when I first start car  (Read 1258 times)
Offline Mk2_tel
« on: 27 October 2012, 16:39 »
It eventually goes but do t sound healthy.
I have a feeling it's from the pulleys or alternator?
Offline james2
  • No scammers please.
Re: Nasty grinding type nose when I first start car
« Reply #1 on: 27 October 2012, 17:50 »
Common fault bet its the starter motor.  :smiley:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #2 on: 27 October 2012, 17:58 »
Sould like the solenoid is sticking on in the starter motor. Common problem. Second hand starter wont cost much.
Offline james2
« Reply #3 on: 27 October 2012, 19:06 »
I would get a new one off ebay .I would not get a second hand one because it might have the same fault or might not last long before it does. Mine been making that stupid noise for over 2 years.  :evil:
Offline mar_k
« Reply #4 on: 27 October 2012, 22:36 »
I followed the guide thats on here or vortex, Can't remember which one now.
Basicly strip it down, clean and re grease. Its been good as gold since,
No need to buy a new one at all
Offline james2
« Reply #5 on: 28 October 2012, 15:40 »
But r-tech did theres and when they came to map my car you can hear the noise coming back.  :evil:
Offline Mk2_tel
« Reply #6 on: 28 October 2012, 17:18 »
It's once the car is already running after say 5secs a quick noise I thought it was alternator as it was smoking when I spray so eved40 on it?
Offline mar_k
« Reply #7 on: 28 October 2012, 17:37 »
Anything hot will smoke when you spray wd40 on it,
I would keep wd40 away from any belts in the bay.
Its probably the secondary air pump,
There is a guide on how to repair that as well, The rivets that hold it together rust away
