Author Topic: Servo removal  (Read 899 times)
Offline Screech16v
  • MK3 20vt AGU
Servo removal
« on: 25 October 2012, 19:20 »
How do you disconnect the rod from the back of the brake pedal,had a quick look but couldnt get it off,theres a white clip ?
Offline Dogbot
Re: Servo removal
« Reply #1 on: 25 October 2012, 19:48 »
Ia very tricky procedure, there are 2 clips that need to be pushed In an then the white clip can be removed, however, you need like 3 hands to do this, so the clip is like a matter of a quid or 2 so yank the feller out, it's the easiest way....
Offline Screech16v
  • MK3 20vt AGU
Re: Servo removal
« Reply #2 on: 25 October 2012, 20:13 »
Cheers dogbot mucho appreciated  :wink:
