Author Topic: headlights dodgey  (Read 1491 times)
Offline lord14
headlights dodgey
« on: 24 October 2012, 16:46 »
i brought the car a few months ago , And when i go to use full beam only one light work and the other one dulls down or stays the same on sidelights , any ideas ? its a 90 spec
Offline sparkplug
Re: headlights dodgey
« Reply #1 on: 28 October 2012, 10:48 »
Earth connections ? mines 1986 not sure if yours is the same but
under the dash slightly above the fuse panel near the ignition switch
is a multiple earth connection block , give em a clean up
1986 GTI atlas grey
Offline Jimmyrallye
  • 20vt goodness
« Reply #2 on: 28 October 2012, 13:21 »
I have this same problem so i assume you mean the light switch take that out the dash and give them a clean ?
Offline sparkplug
« Reply #3 on: 29 October 2012, 17:04 »
no not the switch
 there is a terminal block with several earth connections together
that's riveted to the body
also the golf has separate fuses for left & right headlights
plus high & low beam  :grin: it's a dub thing
« Last Edit: 29 October 2012, 17:07 by totalnuttah »
1986 GTI atlas grey
Offline lord14
« Reply #4 on: 19 November 2012, 20:44 »
so there is a fuse for each headlight , as when i go for high beam as in click the stalk for flash , it just swaps from one headlight to the other
