Golf mk2
mk2 golf gti not starting
Topic: mk2 golf gti not starting (Read 1382 times)
vee-dub
24 October 2012, 14:35 »
hi i have a 8v golf gti mk2 i took the front end off and now it dont start with the front end off is there a reason or will it start when i put it back together do you think
help!!! thanks
Mr Blue
Forum addict
Re: mk2 golf gti not starting
24 October 2012, 15:26 »
If it doesn't crank over then I bet you nocked the starter motor wire
Ignition on then you can always bridge the thick red wire terminal on the starter to the red/black wire terminal.
- car out of gear obviously
vee-dub
24 October 2012, 22:13 »
no it does not and when i did there was little puffs of smoke coming from the engine bay,that could be why i will have a look and get back thanks mr blue.
vee-dub
26 October 2012, 18:18 »
it was the starter motor has completely gone thanks for your help
Golf mk2
