Car audio
Mk2 Golf Stereo
Topic: Mk2 Golf Stereo (Read 2700 times)
capoot
Here all the time
Mk1 Skoda Octavia VRS
Mk2 Golf Stereo
13 July 2005, 19:34 »
My mk2's stereo is ALWAYS on! anyway i can change this just to when the keys are turned? any ideas?
Cheers D
Mr Blue
Forum addict
Re: Mk2 Golf Stereo
13 July 2005, 19:45 »
try switching the red and yellow wires around at the back of the headunit. they just unplug
1 Lp
GTI forum regular
Re: Mk2 Golf Stereo
14 August 2005, 14:02 »
don't swap the red and yellow wires thats for the headunits memory (constant live). u need to check ur main live wire (probably red) is off when the ignition is off. I.e. get a muliti meter and check the red wire is live when the ignition is on, and off when the ignition is off
VWs are like women, they need love care and attention
Mintsauce
Re: Mk2 Golf Stereo
14 August 2005, 16:46 »
I had a similar problem when I first installed my HU; there was a double plug at the yellow wire from the back of the stereo and once I'd plugged the red wire (from the back of the stereo) into the double plug ie together with the yellow wire it worked.
My stereo had an off button which you had to press in order to turn it off (even after the ignition had been switched off).
However now I've mucked it up and I cant even seem to find a permanent live from the car wiring loom....
so when my HU powers up it has no memory.
D4NNY
Re: Mk2 Golf Stereo
03 September 2005, 16:23 »
You might find that if your mk2 is anything like mine, then you will need to put in your own ignition live, i took mine from the back of the hazard light switch, and i think its the black/blue wire. might not be of any help, but there goes
__________________ <br />|^^^^^^^^^^^^ | || __ <br />|___GOLFGTI.CO.UK_| ||'|";\\,_ <br />|(@)'(@)""*''|(@)(@)***(@)__|
Car audio
Mk2 Golf Stereo
