Author Topic: injectors for ARZ 150bhp golf  (Read 2156 times)
Offline james1981
« on: 23 October 2012, 19:12 »
Hi ive been told that my injector/s may be on the way out. i have the mk4 arz engine and wondering if the injectors out of the agu etc engines would work, or the audi tt. i cant seem to find any for the arz only agu etc, and also im used to dealing with diesels that need the injectors programming would i need to do anything like this with these injectors, Or would be possible or worth trying to clean them thanks.
Offline rio_gti
Re: injectors for ARZ 150bhp golf
« Reply #1 on: 23 October 2012, 20:19 »
Need the ones with a long nose  :laugh: but if you go for the tt/s3 they won't just be plug and play
They look like this
Offline littco
« Reply #2 on: 23 October 2012, 21:21 »
I've got some tt 180bhp ones for sale. Should be a direct fit
Offline Dalo Harkin
« Reply #3 on: 23 October 2012, 22:22 »
Who told you it was injectors, more likely to be the fuel pump
Offline james1981
« Reply #4 on: 24 October 2012, 13:30 »
well i originally thought it would be the fuel pump, but the guy at the garage said they rarely go. the fuel pump still primes. It looks like the injector/s may be leaking a bit so ill need seals at the least. Plus theres like a slight tapping noise coming from near injectors does not sound like valve clearance, so he thought the injector/s where going bad. let me know your thoughts or tests that can be done if any to test the theories thanks guys.
also the tt injectors, the guy says they wont be plug and play, if they are and i need them how much and are they in good working order and where can i get seals, been told there different on some of the injectors.
Offline Dalo Harkin
« Reply #5 on: 24 October 2012, 14:06 »
Injectors mainly just need a sonic wash, pumps get tired over time, how long has the current one in probably since the car was built.
You need the Audi TT 225 ones or S3 injectors for the ARZ but they do need mapping in.
Offline james1981
« Reply #6 on: 24 October 2012, 14:14 »
the pump is more than likely the original, ive only had the car 3 weeks and it has done 112k so its more than likely the pump, regarding the injector seals were can i get them from, also if i clean the injectors myself with a ultra sonic what liquid would you recommend using thanks. i do get a bad bad petrol smell first thing when starting with quite a bit of white smoke(like unburnt fuel) also if i put my foot down and the car feels sluggish i get the petrol smell as-well. i have changed the fuel filter so i know its not that, it has been decatted but it has the pre lambda sensor as-well as the post thanks.
Offline rio_gti
« Reply #7 on: 24 October 2012, 14:43 »
think its the decat that makes it smell like unburnt fuel as since i did mine it smells like it runs very rich,
but with what your saying if anything its getting more than enough petrol so the pump and injectord are fine!!!!
so what is the reason you think they are bad? mine tick, just change the seals and go from there, but beware, i got new seals from VW and even thou they were the right p/n they didnt fit (just used the old seals in the end  :laugh: )
Offline Dalo Harkin
« Reply #8 on: 24 October 2012, 15:24 »
There are clips that retain each injector to the fuel rail check they are ok, have you checked that the two bolts holding the fuel rail to the inlet are also tight.
VW wanted around £4 per injector seal  :lipsrsealed:
Offline james1981
« Reply #9 on: 24 October 2012, 15:31 »
ok ill give the seals etc a check when it stops raining if ti stops raining, what fluid could i ultra clean the injectors in.
