Author Topic: INTERCOOLER pipes  (Read 2943 times)
Offline markgti1.8t
INTERCOOLER pipes
« on: 22 October 2012, 20:31 »
90 Degree Silicone Elbow Radiator Hose Bend Silicon Rubber Coolant Rad Air Pipe
63mm x2
90 Degree Reducers Silicone Elbow Bend Hose - Silicone Rubber Coolant Rad Pipe
63mm - 51mm
45 Degree Silicone Elbow Bend Hose - Silicone Rubber Coolant Radiator Pipe
63mm
Metal Alloy Aluminium Hose Joiners Pipe Connectors Silicone Rubber - Select Size
63mm
300mm
Alloy Aluminium Elbow Bends - Pipe Hose Joiner Connector Polished Metal Silicone
90 Degree x2
63mm
45 Degree
63mm
76mm - 63mm x2
could some one confirm this is all the pipes that i need for the intercooler thanks
« Last Edit: 22 October 2012, 21:14 by markgti1.8t »
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline rio_gti
Re: INTERCOOLER pipes
« Reply #1 on: 22 October 2012, 20:48 »
apparently you need 45x63 reducer (i think) off the turbo, a straight 100mm long 63mm metal pipe then 63mm silicone 90 off that
also another 63mm 90 metall bend
and instead of 2x 90 reducers off the core use 1x 90 and 1x45 (havent done this but apparently this fits better) and will be doing this myself
also what engine code have you got? do you have a map sensor?
Offline markgti1.8t
« Reply #2 on: 22 October 2012, 20:59 »
don't have map sensor got the agu and is the k03 not 51mm  and would the 90 pipe coming off the 45 not reach down to the turbo
karls3abo
« Reply #3 on: 22 October 2012, 21:04 »
For the turbo I think it may be a 51mm- 63mm reducer? Mine is an Agu and will be a k03s, i just ordered all the pipes separately on ebay apart from the reducer lol
Out of curiosity can I fit the fmic with the k03 it is mapped to just under 200bhp and If so what is the outlet size off te turbo
Ps.. Sorry to steal your post lol
Offline rio_gti
« Reply #4 on: 22 October 2012, 21:15 »
cold side from tb:
63 metal straight 100mm
63 silicone bend 90
63 metal bend 90
63x76 45 silicone reducer
intercooler
63x76 90 silicone reducer
63 metal bend 90
63 silicone bend 90
63 metal straight 300mm
63 45 silicone bend
63 45 metal bend
63 90 silicone bend
63 straight metal 100mm
63x45 silicone reducer
or
63x51 90 silicone reducer
im not too sure on the turbo as i have one that i measured but someone else has used the 63x45 reducer
dunno if the silicone has to be tight on it thus the 45mm reducer
Offline Dalo Harkin
« Reply #5 on: 23 October 2012, 12:57 »
seems like a lot of pipework that Rio, where did you get all that from, I am messing with mine on Sat morning and I will get some pics of mine to show what I have done, I'm glad I went with the K04 charge pipe and S3/LCR inlet  :grin:
Offline rio_gti
« Reply #6 on: 23 October 2012, 13:22 »
havent got it yet as ash are out of stock on 4 hoses, and i want them all to arrive together!!
just spoke to ap and they say about 4 weeks now  :sad:
i was upset to see a tt charge pipe go for £10 inc postage the other day  :whistle:
Offline Dalo Harkin
« Reply #7 on: 23 October 2012, 17:05 »
for us mate, I would say it's the simpler option  :whistle:
hence the battery moving into the boot  :wink:
Offline rio_gti
« Reply #8 on: 24 October 2012, 13:48 »
which way is simpler?
so what size reducer to the turbo are people using???
Offline Dalo Harkin
« Reply #9 on: 24 October 2012, 14:03 »
K04 charge pipe and S3/LCR inlet  :wink:
