Author Topic: Where does this plug in?  (Read 2660 times)
Offline 67buggers
« on: 17 October 2012, 19:53 »
Any ideas where this goes? Engine is an ABF
This is where the wires start
« Last Edit: 17 October 2012, 20:25 by 67buggers »
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline vwwvgolf
Re: Where does this plug in?
« Reply #1 on: 17 October 2012, 20:03 »
i would go and check mine, but its dark and raining lol
Offline 67buggers
« Reply #2 on: 17 October 2012, 20:14 »
What if i say pretty please  :smiley:
Offline spikenipple
« Reply #3 on: 17 October 2012, 20:32 »
Looks like the plug for the idle switch (at the back of the throttle body).
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 17 October 2012, 20:32 »
Have you only just discovered it, does it run ok?
Offline 67buggers
« Reply #5 on: 17 October 2012, 20:51 »
Its been like it since i had it, it runs fine, has a slight misfire but i put this down to needing new plugs . It does need me too press on the throttle to start it once started it runs a bit lumpy for 10 seconds then its fine, could this be linked?
Offline Dogbot
« Reply #6 on: 17 October 2012, 22:16 »
That my dear friends is the auxiliary heater plug,  not used on uk models but it's plugged onto a plug blank on the plastic breather that goes into the rubber elbow on the throttle body, don't plug it into the throttle stop switch!!!! It will blow fuse 21 (engine electrics) and you will be searching for days as to why it don't idle.... But then, as I've said that if your smart, you'll listen, if your like me you'll be a disbelieving sod and plug it in, just to check like,
 :wink:
Offline 67buggers
« Reply #7 on: 17 October 2012, 22:26 »
Ill believe you! Cheers :grin:
Offline Dogbot
« Reply #8 on: 17 October 2012, 22:30 »
As you can tell, I plugged it in...  :grin: :grin: :laugh: :whistle:
Offline DCmk3
« Reply #9 on: 17 October 2012, 22:38 »
Point taken, if I find a plug laying around I won't just plug it in without researching a bit first.  :rolleyes:
2014 Mk7 GTI - Littco L500
