Author Topic: please remove thread  (Read 1098 times)
Offline Golphie
« on: 17 October 2012, 10:49 »
Sorted. please delete thread
« Last Edit: 18 October 2012, 01:21 by Golphie »
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: garage taking the mick? what you think..
« Reply #1 on: 17 October 2012, 10:53 »
That sounds f**king ridonkulous. The guy/garage sound like a bunch of clowns who don't know what they are doing. Why the f**k would oyu need to order a standard airbox from GERMANY!?  :shocked: I've seen them on ebay for christ sake!
Name and shame and when you head in to pick it up take a lot of confidence and argue like a women!
Offline Golphie
« Reply #2 on: 17 October 2012, 11:01 »
I told him it felt like a electrical fault, it was like putting the brakes on when it boosted  i know a bit about them thats why i took it to specialist as i couldnt diagnose it myself,  had vagcom on it etc, no fault codes..   so it probably was the ECU at fault, but it didnt need a turbo  that worked fine before   yes the sump bung was broke but most garages now use the vaccuum to suck the oil out on a service (even VW do this)
the only thing i said go ahead and do was the turbo as he assured me it would run fine and that was at fault.
so hes fitted all them bits and now it turns out it was the ECU,   still hasnt rang up with a bill after he said its running fine
« Reply #3 on: 17 October 2012, 11:06 »
Do not pay the bill and tell them you never authorized any of the repairs, see what happens after that.
Offline markgti1.8t
« Reply #4 on: 17 October 2012, 12:08 »
take the car for a test run and keep your keys before you start a argument with them so they cant keep your car and demand the money they think you own them
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline Chris#101
« Reply #5 on: 17 October 2012, 12:19 »
So hes run up a bill for more than the cars probably worth  :undecided: ?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline DunnDeal12
  • Limited
« Reply #6 on: 17 October 2012, 13:38 »
jesus christ mate refuse pay as you didn't consent to the work and as scarr says NAME AND SHAME.
Offline jamie1989
« Reply #7 on: 17 October 2012, 14:02 »
Man up and tell yourself he aint having my pants down!
VW specialist should only charge for the parts that actually fixed your car. Everything else tell him to take off and send it back for him to refund. Its not your fault he cant fix diagnose the problem first hand therefore why should you suffer the costs!
His problem so he can sort it out.  :laugh: That is what id do if I ever had to take my car to the garage.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline littco
« Reply #8 on: 17 October 2012, 14:19 »
That's outrageous.
£1400 to rebuild a turbo is nonsense even with labour! I can almost assure you it wouldn't have been a faulty turbo! Ecu????? Nope very very unlikely. Why not buy a second hand one off eBay for £50 to test the theory... Personally suggest you check the ecu is actually a brand new one as I bet it isn't and ask for your old one back as well.
Air box???? Unless they meant maf...
And to do this with out your consent is appalling!
I suggest when you get the bill, post it up.
Offline Chris.
« Reply #9 on: 17 October 2012, 14:28 »
tell him you never authorised the repairs to be done with the extra costs.  He wont have a leg to stand on.  Trading standards on your side here too.
Click For Build Thread
