Author Topic: Green stuff brake pads?  (Read 1043 times)
Offline Tezmax
« on: 15 October 2012, 20:59 »
Anyone out there using Green Stuff brake pads? and if so whats your feed back on them.
Changing my rear disc's and pads over the next few days and considering using them but
wanna hear from u guys first.
Are they worth the price?
Do they do what it says on the tin?
Thanks.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline shaft69
Re: Green stuff brake pads?
« Reply #1 on: 15 October 2012, 21:13 »
Have used them and thought they were brill very low dust too.  :smiley:
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
« Reply #2 on: 15 October 2012, 21:37 »
Ferodo or Mintex are also good choices.
Offline rockmonkey69
« Reply #3 on: 15 October 2012, 21:54 »
I would either stick with: OEM, ferodo ds2500 or similar or just go for an appropriate big brake kit.
EBC employ all these green stuff, red stuff, yellow stuff for seemingly different markets - it's all marketing I'm afraid because whilst they appear to cater for different uses from fast road, track etc it does none of these well. Whether your concerned with longetivity, stopping power, consistency or noise.
My personal experience of them (not on my car but on other cars I've driven before and after fitting) is that they squeal quite a bit when cold as they aren't up to optimum operating temperature, this experience reflects their entire range I've experienced thus far; it takes too long to get up to operating temperature to be what I would deem 'safe' for road use, given the lack of force needed for day-to-day driving. When you do get them up to temperature I'm not sure they are much better than genuine OEM...
Only benefit so far as I can see was that they did produce less brake dust as others have pointed out - which I might add is a characteristic of most good aftermarket brake pads anyway, so nothing special there.
I only just read that it's your rear pads your looking to change, I definitely echo what Wayne has already suggested.
« Last Edit: 15 October 2012, 22:24 by rockmonkey69 »
Offline Dalo Harkin
« Reply #4 on: 16 October 2012, 17:17 »
I have EBC red stuff on the fronts and they do make a difference when your at speed, as for how much difference they make on the rears, 40% of stopping power is the rear so if you have crap fronts don't bother
Offline leigh_harty
  • Audi AGU
« Reply #5 on: 16 October 2012, 17:33 »
Green stuff ive found on my mk3 vr is that they are good on back roads, initial bite is good. But they dont like to stop when they get hot.
Hitting the brakes at say 120mph... they have already faded by 80mph for example.
They say its a 200bhp limit but its more of a twisty slower bitey pad  :smiley:
Dont lose your dinosaur!
Offline Prawny
  • R-tech power!!!
« Reply #6 on: 16 October 2012, 20:31 »
not a fan of green studs, or EBC on the whole for pads.
Have used greenstuffs several times in the past on different cars, and been disappointed every time.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 16 October 2012, 20:35 »
Overated imo. Mintex are my current tipple of choice.
Offline leigh_harty
  • Audi AGU
« Reply #8 on: 16 October 2012, 20:36 »
Yeah i was a little kid fitting them... they dont even give my seatbelt a hard time!
Not the cheapest too   :angry:
