Author Topic: vr6 laking the punch  (Read 1462 times)
Offline jayh
« on: 13 October 2012, 16:44 »
guys im asking for some help ,
i have a vr6 obd2 that is  still quick and drives spot on ,but i notice that some times  she has a lot more punch than other times ,mostly it drives nice right up thru the rev range ,and others will wake you up very lively ,
ive serviced her ,cleaned throttle bodie out ,used injector cleaner cleaned all the connection under the bonnet, then used electrical greese ,
any ideas people ,im stuck
Offline jayh
Re: vr6 laking the punch
« Reply #1 on: 13 October 2012, 16:49 »
also read the ecu ,there is no fault codes ,
Offline tweed
« Reply #2 on: 13 October 2012, 19:31 »
Sounds like ignition to me. So replaces plugs leads coil maybe on its way out
Offline jayh
« Reply #3 on: 13 October 2012, 19:34 »
no miss fire at all ,if it didnt get livley now and again i would just assume this was how it was,cheers
Offline tweed
« Reply #4 on: 13 October 2012, 19:50 »
Who said anything about a mis fire?  :huh:
Offline jayh
« Reply #5 on: 13 October 2012, 19:53 »
i would have thought that if the plugs leads or coil was playing up ,i would see some sort of miss ,i might be wrong ,
Offline tweed
« Reply #6 on: 13 October 2012, 19:59 »
Check if you coil is arcing
Offline Outlawsaffa1982
« Reply #7 on: 15 October 2012, 10:50 »
I had the same problem with my vr when I bought it, goes fine at low rpm but in the higher end its feels like its got no grunt and it would fart and splutter... Turned out to be the coil park.
