Author Topic: Unstable after 85 miles  (Read 1520 times)
Offline kidhannn
« on: 12 July 2005, 13:59 »
Hi,
I have a VW Golf MK1 GTi Cabriolet and have the following questions..
- You can feel the heat coming into the car around the feet (both driver and passenger). Is this normal?
- Driving above 85mph makes the car a bit unstable. Steering starts to shake mainly. Anyone experience this? Any idea whats wrong with it?
Regards
Randeep
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: Unstable after 85 miles
« Reply #1 on: 12 July 2005, 14:40 »
I'll try...
First question - Going to ask - is your heater set to hot position and to the lower tubes - this will produce heat to both driver and passenger feet area.
Second question - I've experienced that - had the wheels balanced and set wheels to the correct pressure. Could also be your front wheel bearings.
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline 10:27
« Reply #2 on: 12 July 2005, 14:44 »
iv had thatto steering rack/ coloum, wheels balanced etc can be a host of things mine was allright but im having my steering rack replaced again and you bearings on the front i surpose it wont get done till i get some money but their you go that the mk1 for you always demanding money and attention :grin:
Offline BobbyT
« Reply #3 on: 24 July 2005, 17:00 »
you might need your wheels balancing, could be tracking too!  :undecided:
Offline dj g
  • vw gals
« Reply #4 on: 25 July 2005, 20:27 »
i had my tracking done and wheel blanced the car is worse :angry:
Offline goodo
« Reply #5 on: 26 July 2005, 08:34 »
When I bought mine, it had been sitting aorund for a couple of years, and althought the tyres had good trea don them, I had quite a lot of wheel wobble over 70mph. I took my car to a tyre shop to get the wheels balanced and the guy told me not to bother. He said if a car's been sitting for ages then the tyres get flat spots, I guess the rubber or silicone compound in the tyre 'creeps' or flows rather like a ball of plasticine (but slightly slower), and you end up with a non uniform weight distribution. So for me the first thing I'll try is new tyres when I get round to forking out for them.
Andy
