Author Topic: where to get mk 3 gti 8v chip?  (Read 12367 times)
Offline whileoceanasleeps
  • patience comes to those who wait.
Re: where to get mk 3 gti 8v chip?
« Reply #50 on: 03 November 2012, 18:55 »
Offline Khare
  • The bear that khares
« Reply #51 on: 03 November 2012, 18:57 »
aha. that makes sense.
this guy must be wrong then...http://forums.vwvortex.com/showthread.php?5467497-How-to-build-a-relatively-inexpensive-reliable-powerful-2.0-8v.
Yup. Judging by the way he wrote that article too it seems he doesn't know much either.
« Reply #52 on: 04 November 2012, 19:23 »
got a quote - £50 to solder new chip from west tuning
Offline spudboy6
  • Just like a golf ......
« Reply #53 on: 04 November 2012, 19:35 »
Stuff that £50 to trick the ecu in to over fueling to advance ignition timing ? I think I'll pass
 :huh:
Offline Khare
« Reply #54 on: 05 November 2012, 00:27 »
 :huh:
Do you even know what the chips from Joe do? No, so stfu.
Offline spudboy6
« Reply #55 on: 05 November 2012, 14:23 »
 :huh:
Come on then what do they do ...
Offline Khare
« Reply #56 on: 05 November 2012, 14:29 »
Well it doesn't trick the ECU into anything.
It's a map that uses the standard AFR trace but adds a bit more fuel at certain points, smooths it out in others. It advances the timing further than the maximum capable using the standard chip and it also raises the rev limiter a bit more. Not needed for 8v's, but a great gain for a 16v.
« Reply #57 on: 05 November 2012, 17:52 »
not needed for 8vs - do you mean just the raising of the rev limiter? I know it peaks way before it hits red anyway
also just wondering khare, do you know if a different 8v Ecu will work with my agg engine? ie non soldered.. long shot but it could be cheaper than soldering - cheers
Offline Khare
« Reply #58 on: 05 November 2012, 18:02 »
Yes I meant the rev limiter increase on the 8v is pointless.
And no, the early 2E ECU is designed for a different management system, it won't work. Your chip is specially designed to be soldered in, push fit chips are a different size and fit.
