Author Topic: OMG SHES GOT A HOLE !!!  (Read 4230 times)
Offline Screech16v
  • MK3 20vt AGU
Re: OMG SHES GOT A HOLE !!!
« Reply #10 on: 11 October 2012, 20:54 »
That hole will be a bit bigger by time youve cut back and cleaned up,but yeah as said a nice one to do!
garages vary so much when it comes to welding ,price and quality ,get it done to cheap and you know its going to be crap ,id say £50-60 done properly  .
Offline tshirt2k
  • Been there...Done that...
« Reply #11 on: 11 October 2012, 20:55 »
Very common problem. You'll probably find a few more bungs are rotted too.
It wasn't that bad, but had to cut it all out.
Passenger side
Drivers side
Welded in the plate from the inside and smoothed off the welds with a flap disc.
Tacked in drivers side.
Passenger side smoothed off
Both sides, inside and out were cleaned up, sprayed with zinc primer then seam sealed on the welds.
Then the inside was painted with some satin black and the outside was undersealed.
« Last Edit: 11 October 2012, 21:02 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline Screech16v
  • MK3 20vt AGU
« Reply #12 on: 11 October 2012, 21:10 »
Good solid repairs that are going to last ^^^^^^^
Offline 67buggers
« Reply #13 on: 11 October 2012, 21:30 »
What are the bungs for?
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline Itteh
  • Built Not Bought
« Reply #14 on: 11 October 2012, 21:38 »
id love t know how to do that, il have to give it to a garage, the cars parked up.... wont b on road for another couple months, will it get worse or shud i get it sealed up asap ? as winter is coming, and i have some crust on the bung next to it.... its only drivers side that effed up the passenger side is like brandnew, nothing what so ever... if i get the under neeth sealed with underseal, will that help ?
Offline trog_nfs
« Reply #15 on: 11 October 2012, 21:54 »
To plug the drainage holes used for when the shell is dipped in primer in the factory. They let any excess drain out. They don't always get sealed properly.
Offline 67buggers
« Reply #16 on: 11 October 2012, 22:02 »
Always wondered,  now I know!
Offline Bellend
« Reply #17 on: 11 October 2012, 23:30 »
Probably literally charge 60-70 quid to do that and strip back the underseal in the close proximity too check it's not spreading underneath.
Zinc, then seam seal, underseal, stone chip underneath then paint.
Not as long as it seems at all.
Where all my moneys went.
Offline tshirt2k
« Reply #18 on: 12 October 2012, 12:25 »
You have to be careful on one of the sides as there are brake or fuel lines (can't remember which)running close to those areas.
Almost all of the bungs running allong the sill on the nearside had traces of rust on mine, and it does spread under the underseal and you can't tell by looking at it.
To be sure, i removed all bungs and had a look. They weren't bad, but i cut any rot out anyway and welded a plate, to save grief later.
Most people wouldn't bother, but I was underneath in a pit, in a warm(ish) garage, so i carried on with it. :huh:
Cavity wax and epoxy resin paint should keep rust at bay.
Offline sharki786
  • GOT BOOST??
« Reply #19 on: 12 October 2012, 13:17 »
lucky for some!! :cool:
im thinking about moving the living room furniture into the kitchen digging out the living room and park my car in there lol
the brake lines are on the passanger side and the fuel lines are on the drivers side, unless both are on drivers side.
*****MK3 Anniversary*****
*****MK4 GTI T*****
