Author Topic: Heater Matrix pssibly on the way out - is a cheap fix worth it?  (Read 6411 times)
Offline andykram
Over recent weeks when I've moved the heater lever off its cold setting I've had 20 seconds of a "burning" smell, followed by massive misting of the windscreen which has taken ages and ages to clear.
Yesterday I even had steam coming out of the vents when I turned the heater on, 20 miles into my journey. This was followed shortly after by the red temperature light coming on. I pulled over, waited a few minutes for it to cool down then managed to get to work without any further problem.
Home time comes round so I check a cold engine and the coolant is way below minimum. I top it up and get home without a problem.
Anyway, I'm thinking this is far more likely to be a heater matrix issue than an actual coolant leak as there is absolutely no indication elsewhere of the latter. No obvious leaks anywhere, nothing under the car, temperature gauge absolutely rock solid on the first mark etc. etc.
However, there's clearly some moisture lurking somewhere and, with the screen misting so badly, I suspect a slight leak in the heater matrix somewhere. So my question is, is it ok to sort this with a juicy dose of sealant or is that just putting off the inevitable of changing the matrix? I wanted to avoid the drama of pulling the dash to pieces to sort that. What do you experts reckon?
Offline andykram
No moisture in the foot wells either before anyone asks.
Offline Jimmyrallye
  • 20vt goodness
Ive got same problem on my 1.8 digi had no heat from blowers when engine hot also lost a tad of water ... Ive now put a 20vt turbo engine and its doing same thing :( im going to change the matrix at the weekend
Offline Gambit
Just change it, you dont need to pull the dash to pieces. Its just undertrays and centre console you need to remove to access. Itll take a couple of hours to change
and before you fit new make sure you clean all the protective oil of it, otherwise youll get an oily residue on your window for about 3mths after it while it slowly burns off
also remove bypass valves as new matrix wont need them as its a superceeded mk3 part you fit
Offline andykram
If people reckon that's the best way forward to put a new one in, it's going on for a full engine refurb at the end of this month so I reckon a sealant job will do for a few weeks and then I'll get one put in when the engine is out and everything's being cleaned up.
This also saves me having to fanny around sticking a new one in for the sake of three weeks.
Offline Thom89
  • Looking for an "Icebreaker"
All you need is here.... http://www.golfgtiforum.co.uk/index.php?topic=68989.0
As said many times over, use only Valeo, or Behr branded units, others leak after a few months! be warned!
GSF do them. at around £40ish, ask for a Mk3 matrix, which is the same fittment, but heavier duty...
Thom
Offline Gambit
You could even ask for a mk4 one if ya wanted. They are all the same part. If getting from gsf ask if they have any better quality items. I got a hella heater matrix from them though that was years back
Offline rumlad
I did it not long ago, followed one of the 'how to' threads and was very straight forward. Did it over the course of a few evenings, can be a bit fiddly, and did involve a fair bit of sitting upside down with my head in the footwell, but not difficult at all.
As said, get the mk3 matrix, and if your car has one, remove the bypass valve.
Offline andykram
Spoke to the mechanic today and it's definitely the matrix. So off we go on the hunt for a Mk3 jobby!!!
Offline Sam
  • Sam I am
If your not bothered about the heat for a few weeks just plug the water pipes into each other and keep your heating turned off
