Author Topic: Heater Matrix pssibly on the way out - is a cheap fix worth it?  (Read 6690 times)
Offline rob.043
Re: Heater Matrix pssibly on the way out - is a cheap fix worth it?
« Reply #10 on: 11 October 2012, 16:28 »
Yeah just replace the patrix rather than compromising everything else with a sealant that may not do anything but block your radiator!
« Reply #11 on: 13 October 2012, 00:11 »
Better in the long run to fit a new matrix.
Offline dubber36
« Reply #12 on: 14 October 2012, 09:16 »
Spoke to the mechanic today and it's definitely the matrix. So off we go on the hunt for a Mk3 jobby!!!
James replaced my matrix earlier this year. We also managed to source some replacement pipes to do away with the bypass valve.
Offline vii-cks
« Reply #13 on: 14 October 2012, 11:17 »
If your not bothered about the heat for a few weeks just plug the water pipes into each other and keep your heating turned off
Do that temporarily to prevent misting etc, heater matrix's are so common usually with a damp footwell though? Not always the case. Good luck changing it, it's always been known as a bit of a mission to do.
