Author Topic: Knocking noise  (Read 3539 times)
Offline Willo
Knocking noise
« on: 06 October 2012, 11:59 »
From rear passenger side of car is there sometimes but not others and is only when the suspension is traveling help please
Offline tweed
Re: Knocking noise
« Reply #1 on: 06 October 2012, 12:20 »
Rear beam mount or top mount.
But I would firstly check to see if the exhaust is loose.
Offline CJA321
Re: Knocking noise
« Reply #2 on: 07 October 2012, 00:09 »
+1
Offline Willo
Re: Knocking noise
« Reply #3 on: 07 October 2012, 12:13 »
Could a leaky shocker be the cause ?
Gavv8
Re: Knocking noise
« Reply #4 on: 07 October 2012, 12:17 »
Possibly but you'd notice that more as the back end would feel all loose and wallowy, the previous posts are more likely as the rear suspension on a mk3 is pretty simple.
Offline Willo
Re: Knocking noise
« Reply #5 on: 07 October 2012, 13:15 »
I know my shocker is leaking looked at it today and there's more fluid out of it than in it
Gavv8
Re: Knocking noise
« Reply #6 on: 07 October 2012, 13:26 »
There you go then best get it changed as its a dead easy job to do and your probably better off changing both sides and the top mounts too then you'll know its all shipshape. :afro:
VW BUSH
Re: Knocking noise
« Reply #7 on: 07 October 2012, 13:54 »
I would also change the spring plates as they rot through :wink:
Offline tweed
Re: Knocking noise
« Reply #8 on: 07 October 2012, 15:14 »
f**k it buy a fall shock and spring set up with new top mounts
Gavv8
Re: Knocking noise
« Reply #9 on: 07 October 2012, 15:25 »
Just a thought but is it a GTi/VR?
