Author Topic: k03 hybrid with 41mm ind and 59mm exd  (Read 4505 times)
Offline markgti1.8t
« on: 05 October 2012, 19:19 »
hi there what would make the most power of the three turbos and for best acceleration thanks
« Last Edit: 08 October 2012, 18:46 by markgti1.8t »
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline cullygti
Re: k03 hybrid/k03s hybrid or k04-001
« Reply #1 on: 05 October 2012, 21:02 »
they will all pretty much make the same power tbh with the correct suporting mods ..... ko3s hybrid is more or less a ko4 001 from what i believe  :smiley:
Offline markgti1.8t
« Reply #2 on: 05 October 2012, 21:19 »
was talking to a turbo technician and he says he would make me a k03 hybrid for £265 would it be better to go k03s hybrid or just buy a k04-001
Offline markgti1.8t
« Reply #3 on: 05 October 2012, 23:48 »
k03 or k03s hybrid
Offline CyRuS
« Reply #4 on: 05 October 2012, 23:54 »
franken turbo o loba k03 rules
Offline Scott D
« Reply #5 on: 05 October 2012, 23:54 »
Depending on the internals likely to get more out of a k03 hybrid than K04-001.
260bhp & 300 ft/lb is possible from a K04-001 with all the right supporting mods
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline markgti1.8t
« Reply #6 on: 06 October 2012, 00:14 »
what you think the k03 hybrid would reach with all supporting mods
Offline Scott D
« Reply #7 on: 06 October 2012, 00:22 »
Offline markgti1.8t
« Reply #8 on: 06 October 2012, 00:59 »
if i was to do the k03 hybrid would i need to remap straight way or could the car be driven with standard map
« Last Edit: 06 October 2012, 01:12 by markgti1.8t »
Offline littco
« Reply #9 on: 06 October 2012, 10:09 »
K03 and k03s hybrids end up the same thing. K04-001 will see 250-260bhp whilst a hybrid k03 will get 280-300bhp depending on the spec. They can be run on a stick car/map providing you unplug the n75 till its mapped.
