Author Topic: Direct bolt on k04-023 for the AGU ARZ AUM AUQ engines 280bhp 280lbft  (Read 16963 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
This is a heads up for people who are planning to go hybrid or big turbo setups on there 1.8Ts.
We are curently testing a new turbo setup for another company on a 1997 Audi A3 AGU.
Basically is a full K04-023 (TT LCR S3 225bhp turbo) core and wheels squeezed into a k03 turbine housing.  It seem they guy building the turbos has his the nail on the head and got it to flow perfect.
So far the live mapping session has managed to hit 274bhp 270lbft 22psi peak and 19psi held.  This setup is running a forge actuator with yellow spring which is cracking open at the top end, so could do with a blue spring to gain another 10bhp.
The cars hardware setup is 2.5" FMIC and pipes, saab red injectors, 3"VR6 MAF, 80mm TIP, full turbo back exhaust, ported stock exhaust manifold.
I have the guys at Relentless to produce a k03 high flow manifoldm which should help take this setup to 290bhp+, and maybe on the limits of the turbine flow.
From what I have seen so far this turbo setup out performs the CR RS6 hybrid by far, its make the power with less effort and flow much better across the whole rpm range.
I will try and get some graphs up when I have finished.. :wink:
more info can be found on ASN user name beachbuggy (Dan)
Nick
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
You have been a busy boy :afro:
Offline cullygti
i am liking the sound of this  :cool:
Offline jamie1989
Now we are talking!!!  :cool:
Seen you yesterday cully heading towards Cardiff on A470 about 7.30 looking good mate  :wink:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline cullygti
cheers dude  :smiley:
where was you dude im working in trefoerst ind est at the mo so may see me most mornings if your about  :smiley:
Offline Toby
  • Car - less
Very nice results!!  :cool: agu ftw!!!
Currently down under
Offline jamie1989
Awsome dude youl see me tomoz then hopefully I usually catch a lift an give the bora a break but im in on my own tomoz  :cool:
These turbos sound mental and the credit card needs a tuning  :whistle: Hurry up R-tech  :grin:
Offline Granta Gti
Wow that's impressive!  :smiley:
Offline jamie1989
Just read abit on ASN and WOWWW I cant wait for these turbos  :grin:
Offline rio_gti
this does make me moist........ so water meth is not necesery? and also it is a k03 inlet (where the tip goes on)?
