Author Topic: Nankang NSII's  (Read 2494 times)
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
Nankang NSII's
« on: 30 September 2012, 14:00 »
Anyone got any reviews on the Nankang Ns2's?
Mk4 Gti - Gone but not forgotten!
Offline barrym381
Re: Nankang NSII's
« Reply #1 on: 30 September 2012, 14:10 »
cheap an nasty is my 1st thought  :wink:
Offline Xtrhardcore
Re: Nankang NSII's
« Reply #2 on: 30 September 2012, 14:12 »
LOL - i've got some on my mk4, they seem to be doing alright at the moment! Very noisey though?
Offline justalex81
Re: Nankang NSII's
« Reply #3 on: 30 September 2012, 14:35 »
great for some sideways action on FWD's
Offline Scott D
Re: Nankang NSII's
« Reply #4 on: 30 September 2012, 20:29 »
Had NS1s years ago and they was dangerous in the wet - easily lock up without applying much pressure and could spin in the dry with 80bhp FWD powah.
NS2s are ment to be better but I wouldn't trust any Nankang tyre again after previous experience.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Xtrhardcore
Re: Nankang NSII's
« Reply #5 on: 30 September 2012, 20:58 »
My NSII's are pretty good in the wet tbh, only spin if i give it beans when pulling away. And i feel they've got amazing grip for low end performance tyres tbh.
Offline JamesS
Re: Nankang NSII's
« Reply #6 on: 08 October 2012, 14:17 »
I wouldn't even consider them. They are just dangerous! Very limited grip in dry and are horrendous in the wet. If you can't afford new tyres get part worn higher quality tyres. Yes, they may only have 4mm of tread but you won't find yourself imbedded in the back of someone elses car or in a hedge. I have been in a friends e46 M3 with Nankangs on the rear and you can feel the car drifting accross the road at 60/70mph it's the most disconcerting feeling and gives you no confidence. It's the same story in a 350z only it's even worse, the back end would step out so easily at 20mph it was comical.
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline robjackson
Re: Nankang NSII's
« Reply #7 on: 10 October 2012, 22:27 »
Bridgestones it is then!
Re: Nankang NSII's
« Reply #8 on: 12 October 2012, 21:47 »
Worst tyres I have ever used.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: Nankang NSII's
« Reply #9 on: 12 October 2012, 22:15 »
Nankang NS1 and NS2's are shockingly bad  :shocked: avoid!
