Author Topic: Steering wheel movement  (Read 2756 times)
Offline WeekendMechanic
  • Golf MK3 GTD
« on: 29 September 2012, 17:54 »
My steering wheel moves around when I apply little pressure to it all round,I tightened the steering wheel nut but it did not have any affect, how am I going to rectify this problem?
Offline spikenipple
Re: Steering wheel movement
« Reply #1 on: 29 September 2012, 18:56 »
Sounds like the steering column bearing.
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 29 September 2012, 18:58 »
+1 to this,mine is the same.
  • Golf MK3 GTD
« Reply #3 on: 29 September 2012, 21:50 »
I figured it was the steering column bearing,Ho do I get to it do I have to take the whole column out?will I need to take the dashboard out?
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 29 September 2012, 22:12 »
Dash and windscreen has to come out and you have to lower the tyre pressures to 23 psi :laugh:
Steering wheel ,cowling,stalks and spline adapter have to come off then you can get at the bearing
Some pics and part numbers here ..
http://www.golfgtiforum.co.uk/index.php?topic=229213.msg2110041#msg2110041
  • Golf MK3 GTD
« Reply #5 on: 30 September 2012, 10:40 »
Thanks that tread is very informative,lol @ Tyre pressure :tongue:,
« Last Edit: 30 September 2012, 10:56 by WeekendMechanic »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 30 September 2012, 12:05 »
Check the shear bolt on the column below the plastic cowling, both of my past mk3's have been loose allowing loads of movement in the column and stalks.
Offline Paul86S2
« Reply #7 on: 30 September 2012, 19:53 »
Yes check this first, I have just done mine and the bolt was missing. Fitted a new normal bolt and its rock solid again.
Paul
  • Golf MK3 GTD
« Reply #8 on: 30 September 2012, 21:29 »
checked it mine still is wobbly though :S
« Reply #9 on: 30 September 2012, 22:27 »
Swap it for a normal one then if you can't tighten it properly, it makes loads of difference although to be fair its a shear bolt for a reason and I'm assuming its to allow the steering column to move if involved in an accident rather than been totally solid for the driver to impact.
