Author Topic: Steering wheel movement  (Read 2767 times)
Offline Screech16v
  • MK3 20vt AGU
Re: Steering wheel movement
« Reply #10 on: 30 September 2012, 22:54 »
My understanding of the shearbolt is an anti tamper device against the crims
Offline WeekendMechanic
  • Golf MK3 GTD
« Reply #11 on: 11 October 2012, 19:32 »
I replaced it with a bolt it looks as if the bolt is less dense,are you sure?
Offline Screech16v
  • MK3 20vt AGU
« Reply #12 on: 11 October 2012, 21:06 »
Shear bolts are there to secure the ignition lock, it was written into  car manufactures rules and guidelines time ago,where steering locks are fitted they must be protected by an anti tamper fixing,which is stupid as itS pi$$ easy to break the lock anyway.
« Reply #13 on: 15 October 2012, 21:20 »
Top column bearing breaking up is very common on mk3's can be easier in the long run to replace the upper column.
Also shear bolts are fitted for a reason.
