Author Topic: Dash Clock...  (Read 1620 times)
Offline afcharlie
Dash Clock...
« on: 08 July 2005, 18:39 »
83 Cabby...My golf was serviced last week for the engine problem...which ended up being a faulty air metering unit...now my in dash clock is off...I'm wondering how to set it to the correct time...all I can think of is disconnecting the battery will reset it to midnight...anyone know.
You think you know...but chances are...you know more then me.
Offline dj g
  • vw gals
Re: Dash Clock...
« Reply #1 on: 08 July 2005, 21:52 »
what type of clock is it this happened to my digital clock have MFA so was told to disconnect battery and it worked :grin:
Offline BobbyT
Re: Dash Clock...
« Reply #2 on: 08 July 2005, 22:11 »
my mfa has stopped working, do you think if i disconnected the bat it would work??  :undecided:
Offline mk1
Re: Dash Clock...
« Reply #3 on: 09 July 2005, 07:48 »
Yes, disconnect the battery for a while and reset the time as usual.
Steve.
Offline hairyarse
Re: Dash Clock...
« Reply #4 on: 13 July 2005, 16:33 »
Also check (esp. if engine work has been done by garage!) that the earth strap is present at the right rea rocker cover nut. If it's missing will cause lots of elec probs! :evil:
