Author Topic: sai help please  (Read 1006 times)
Offline streetbeef
sai help please
« on: 19 September 2012, 10:37 »
Last week i removed the sai and all associated bits and bobs and fitted the forge blanking plate. Problem is now i know that the ecu will store the low flow rate code. But i was under the impression it wouldnt bring up the management light  :undecided: i also have a resistor fitted to the plug that went to the pump. I clear the code but the light always comes back on 2 days later. Any adice would be great.
2000 indigo blue golf gti AUM, full oe r32 kit, xenon headlights, r32 wheels, r32 interior trims,steering wheel,pedals and foot rest, h&r springs, r32 milltek cat-back, stage 1 remap, forge diverter valve.
Offline Dalo Harkin
Re: sai help please
« Reply #1 on: 19 September 2012, 12:30 »
which resistor did you use?
did you solder the wires of choc block them?
Offline JimBR
Re: sai help please
« Reply #2 on: 19 September 2012, 16:19 »
You can get it mapped out by R-Tech/Shark or the likes.
Offline streetbeef
Re: sai help please
« Reply #3 on: 19 September 2012, 18:36 »
i think it wasd a 330w 10ohm resistor iirc..  its just strange because my friend has a mk3 ibiza cupra and has done the exact same thing and his eml hasnt come on once  :sad:
Offline Mr_Orange
Re: sai help please
« Reply #4 on: 20 September 2012, 19:16 »
Even with a resistor the AUM will throw incorrect flow code with CEL on dash.  Have a word with R-Tech, it can be mapped out of the emissions readiness check code.
Build thread clicky
