Author Topic: Mk3 GTI subframe, mk4 02J gearbox combination  (Read 6977 times)
Offline Dave_IOW
« on: 14 September 2012, 19:52 »
So, what driveshafts do I use?
Will 02J ones work, or do I need the 02A ones and fit the 02A cups to the 02J box?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline tshirt2k
  • Been there...Done that...
Re: Mk3 GTI subframe, mk4 02J gearbox combination
« Reply #1 on: 14 September 2012, 20:46 »
You answered your own question. Bolt in cups only.
Mk3 ABF 16VT Megasquirt V3
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 14 September 2012, 23:25 »
Sure of that?
Got any examples where people have tried it?  Driveshaft length to illustrate?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #3 on: 14 September 2012, 23:29 »
use mk3 gti shafts, mk4 fits on passenger side but is too long on drivers side
Not no ordinary GTI....
www.mixcloud.com/kells/
  • Opinions я Us
« Reply #4 on: 15 September 2012, 00:03 »
Have you tried the stronger Golf4 shafts then Braddy?
Offline F17BAD
« Reply #5 on: 15 September 2012, 00:30 »
yea i did lol, not so strong after all, well the CV joint is what shattered
now running MK 3 GTI shafts with the 02J box
Offline tshirt2k
« Reply #6 on: 15 September 2012, 08:56 »
02j is same as late 02a. Swap 108mm cups if it has them for 100mm 02a bolt in cups. Job done. As demonstrated on F17 bad. He doubted my advice at first.  :rolleyes:
« Last Edit: 15 September 2012, 09:00 by tshirt2k »
  • Opinions я Us
« Reply #7 on: 15 September 2012, 09:03 »
So is it that the shafts are less strong, or the wrong length, or that someone ran them at an odd angle?
Or is that much analysis too much?
Offline tshirt2k
« Reply #8 on: 15 September 2012, 09:25 »
I think I checked part numbers and nearside is the same.
Offline F17BAD
« Reply #9 on: 16 September 2012, 19:24 »
the shafts on a mk4 weigh less.. so ill let you decide if they are stronger
drivers side mk4 is too long for mk3 or mk2 going widetrack using mk3 subframe
the mk3 ones have been at a odd angle on my car for 5 years with no issues..
maybe my mk4 one was a bad item or the CV joint was worn (we think it was)
Russ i never changed my cups. my old box was a late 02A, it had 100mm the same as 02j .
:smiley:
