Author Topic: Mk3 GTI subframe, mk4 02J gearbox combination  (Read 6349 times)
Offline Dave_IOW
Re: Mk3 GTI subframe, mk4 02J gearbox combination
« Reply #20 on: 16 September 2012, 22:18 »
So there is a chance that mk3 shafts will fit straight onto my 02J?
T-Shirt, when your on about tripod, what exactly do you mean? The CV joints on mine are the tripod style, as opposed to the cylindrical type ones? This mean I will have the bigger cups?
Thanks for the replies aswell  :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline tshirt2k
  • Been there...Done that...
« Reply #21 on: 17 September 2012, 18:50 »
The T Shirt knows  :evil:
rebel with a cause  :grin:
You know.  :grin:
Tripod refers to the 3 arms that connect to the driveshaft inside CV joint. Iirc they are the o rs with the bolts on tabs around the edge of the cv joint.
If you have this type, you have to remove the by undoing the 6mm Allen key in the centre of the cup and replace with late 02A 100mm cups. Then the mk3 shafts will bolt up to the cups correctly.
Mk3 ABF 16VT Megasquirt V3
