Author Topic: mfa oil temp  (Read 1359 times)
Offline pal1
mfa oil temp
« on: 07 July 2005, 17:49 »
the oil temp on my mk2 8v has stopped working  :sad:
where abouts is the sensor located so i can get a new one?  :smiley:
Offline workhorse '90 8v
Re: mfa oil temp
« Reply #1 on: 07 July 2005, 21:31 »
yep, mine too
what year is yours?
mine is a 91 8v.  i'm guessing the faulty bit is the temperature sender located directly on top of the oil cooler. that is asuming your wiring is intact and not to blame.
anyone else any ideas? as i wouldn't mind fixing it, it's always nice to keep an eye on your oil temp..
Offline monzablue16v
Re: mfa oil temp
« Reply #2 on: 07 July 2005, 23:34 »
thats the fella get it swapped out but if I remember correctly its a tapered thread so beware!
Judderi
Re: mfa oil temp
« Reply #3 on: 08 July 2005, 08:39 »
Its more likely to be the wiring to the sensor. Check this out 1st
Re: mfa oil temp
« Reply #4 on: 09 July 2005, 16:30 »
On an 8v the sender is on the oil filter housing, its the small one with the spade connector on top.  On a 16v its round the back of the head somewhere.
