Author Topic: Need Help...!!! Radiator fan not working.....  (Read 3724 times)
Offline barrym381
Re: Need Help...!!! Radiator fan not working.....
« Reply #10 on: 15 September 2012, 10:58 »
did you check the thermo before fittin it  :smiley:
Offline sidman
« Reply #11 on: 15 September 2012, 11:07 »
i didnt....how do i test it....?
Offline barrym381
« Reply #12 on: 15 September 2012, 11:08 »
drop it in boiling water see if it opens
Offline sidman
« Reply #13 on: 15 September 2012, 11:09 »
sorry...thought you meant the temp sender switch.....
Yes i did test the thermostat in boiling water and it did open
Offline barrym381
« Reply #14 on: 15 September 2012, 11:14 »
did you check the return pipe to see if anythin is coming through it
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 15 September 2012, 11:50 »
very common for the fan module to give up if you've got climate
Offline sidman
« Reply #16 on: 15 September 2012, 12:36 »
i ahve just done another scan for fault codes and its come up with this:
VCDS-Lite Version: Release 1.1
Saturday, 15 September 2012, 12:33:22.
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine       Labels: Redir Fail!
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00028
   VCID: 69A53EA70077
No fault code found.
Readiness: N/A
Address 03: ABS Brakes       Labels: 1J0-907-37x-ABS.LBL
   Controller: 1J0 907 379 Q
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 00028
   VCID: 3FF1C0FF2E73
Any ideas...?
And water was flowing through the return pipe fine
Offline sidman
« Reply #17 on: 15 September 2012, 14:12 »
right, a quick update.....
I have been reading through other threads and it said another way to test the water pump is to get the car up to temperature and turn on the heaters. If they blow hot air then the pump is ok. But if they blow cold air the pump has had it...and guess what......mine was blowing cold air...think a new water pump is on the cards......
Offline barrym381
« Reply #18 on: 15 September 2012, 14:18 »
if the belt has not been done in a few years do that aswell while you have it off  :smiley:
Offline itavaltalainen
« Reply #19 on: 15 September 2012, 14:27 »
just one thought: temp sender does not equal fan thermo switch.... does the fan run if contacts at the switch connector are bridged? If yes, then most likely a faulty switch.
