Author Topic: Need Help...!!! Radiator fan not working.....  (Read 3723 times)
Offline sidman
« on: 12 September 2012, 18:40 »
Can anyone help me..? My mk4 Golf GTI T started overheating last night. So i eventually got it home and today bought a new thermostat and temp sender. I put both parts on but the fan still doesnt come on...!!!!
Ive only had the car a few weeks and starting to lose faith in it......PLEASE HELP?
Or does anyone know a reliable mobile mechanic in the Romford area...?
Offline sidman
Re: Need Help...!!! Radiator fan not working.....
« Reply #1 on: 12 September 2012, 18:58 »
ive just taken a fuse out of the fuse box and both fans run constantly. It was a 10amp fuse that was top left, 2nd in. Does anyone know what this means...?
Offline sidman
« Reply #2 on: 14 September 2012, 13:23 »
To add to my confusion...i got to work this morning (i only work 15 minutes from where I live so the car doesnt overheat in that distance) and the fans were going....so i left the engine running and the car still overheated.......Im starting to think it is the dreaded head gasket.....but please someone help me and give me some advise.... :-(
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 14 September 2012, 15:38 »
do you get water running back into the header tank via the small top pipe when it's warm?
Offline sidman
« Reply #4 on: 15 September 2012, 08:46 »
yes I do so I know the water pump is working.......
ive done a bit more research and im gonna test the fans today to see if they run at both speeds....and im leaning towards the fan module now
Offline turbokid23
« Reply #5 on: 15 September 2012, 09:26 »
Sound a bit mad but have you thought about your thermostat?
Offline sidman
« Reply #6 on: 15 September 2012, 10:34 »
ive replaced the thermostat and the temp sender...
Just had a diagnostic tool come in the post today and its throwing up error code 16501 which is the temp sender that i have replaced....im gonna take the pipe off for the water pump return to the reservoir and see if the water is pumping through......this one has stumped me
Offline barrym381
« Reply #7 on: 15 September 2012, 10:37 »
you might get some water comin through the return even if the waterpump is f**ked
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 15 September 2012, 10:43 »
you got climate or just air con? Genuine temp sender?
Offline sidman
« Reply #9 on: 15 September 2012, 10:53 »
ive got climate control and i got the temp sender from VW so it is genuine part...
Are there any other tests i can do to see if the water pump has had it...?
