Author Topic: pressure drop between turbo and throttle valve (check d.v. ) P1297  (Read 4833 times)
Offline brown29
Hi am getting the following code and my car is not running as well as it normally can:
Could this be a problem with the dumpvalve or a split pipe?
How can I check these issues out?
Thanks.
MK4 1.8T GTI
Offline rio_gti
Both!!!
check the seal between the pipes at the back of the engine bay - the one that connects the charge pipe to the pancake pipe its the rubber one where the 'c' clip is (look for oily residue)  :wink:
Offline Nino
  • Insta - F6UGA
Im still trying to find the same fault on mine too, Rio, When I took that pipe off and looked at it it seemed fine but had alot of oily residue like you said to look out for, but I swear he pipe looked fine?  :huh:
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline rio_gti
Was it oily on the outside near the connection or just the inside??
Offline toby2can
i had that on mine and it was a dirty throttle body the garage said full of carbon, they cleaned it an its been fine since.
2002 Golf Gti AUM
Offline Nino
  • Insta - F6UGA
Mostly on the inside but had done on the outside too
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Stock or tuned?
80% of the time the 17705 fault is down to a SW bug, the other 20% could boost leak, vac leak, or weak actuator.
Nick
 01455 617233
Offline Nino
  • Insta - F6UGA
Stock or tuned?
Nick
Mine is compeletly stock AUM Kos3 I beleave?
