Author Topic: will this inductiin kit fit?  (Read 1359 times)
Offline GTiLuke
« on: 09 September 2012, 14:29 »
http://www.txautosport.co.uk/blue-cotton-sports-induction-cone-air-filter-92-p.asp
nk4 gti 1.8 20v turbo, will this fit?
any help asap is appreciated
thanks
luke
Offline itavaltalainen
Re: will this inductiin kit fit?
« Reply #1 on: 09 September 2012, 14:41 »
It might but pointless, if you want get a "sports" filter that fits your OEM filter box...
You won't gain anything with mushroom type filters as they suck in hot engine bay air rather than cold(er) air from the outside.
Offline GTiLuke
« Reply #2 on: 09 September 2012, 14:45 »
i have a heatshield anyway, just wanting to know if this will fit. am i right in thinking the afm is 70mm ?
Offline Gary022
« Reply #3 on: 09 September 2012, 15:28 »
ive just installed a cold air induction kit and its all 67mm diameter so your 70mm will fit perfect with a jubilee clip
Mk4 Golf Gti 1.8T
Custom K&N CAI / Forge 008dv / 3" Turbo Back Exhaust with Highflow Sports Cat / Pressed Plates / Carbon Wrapped Interior Trim / 18" BBS CH Reps
Offline GTiLuke
« Reply #4 on: 11 September 2012, 20:47 »
Anyone else help ? Not sure if this will fit or not ? Not sure what size the standard 1.8t afm is.
Need help from the guys who know. Will it fit ?
« Reply #5 on: 11 September 2012, 21:48 »
Yes but you would be better with a Pipercross foam filter as they will not lead to maf issues that oiled filters tend to cause.
« Last Edit: 14 September 2012, 21:56 by Wayne »
