Author Topic: Front wheels getting hot.  (Read 2507 times)
Offline stainesy
« on: 07 September 2012, 18:28 »
I noticed today that both my front wheels get very hot after a drive. Is this coz it has old Gassion solid brake discs.
Offline Gambit
Re: Front wheels getting hot.
« Reply #1 on: 07 September 2012, 19:25 »
Nah its more likely to be partially seized calipers mean its not full retracting
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 07 September 2012, 19:32 »
Or Wheel Bearings??
For More Info Click To See;
Offline stainesy
« Reply #3 on: 07 September 2012, 19:33 »
But it's both front wheels. And they spin freely when hacked up.
Offline stainesy
« Reply #4 on: 07 September 2012, 19:47 »
They are hot but not to hot you can hold your hand on them.
Could it not be as it has standered tiny 1985 jetta 1.6 non vented brake discs with 8 inch wide wheels on them?
Offline JC
  • Back in the North.
« Reply #5 on: 07 September 2012, 21:10 »
wheel size wont effect the brakes.
i will have the same brakes - cant say I have noticed the wheels being THAT hot to be fair  :huh:
Offline stainesy
« Reply #6 on: 07 September 2012, 21:46 »
What do you recon it could be then if brakes ain't seazed and bearings ok?
Offline danny_p
« Reply #7 on: 07 September 2012, 21:48 »
your ragging it lots ????
usd t get 239 solid  glowing red  just driveing home from work  every day
all the VW's have gone bar 1.
Offline JC
« Reply #8 on: 07 September 2012, 21:49 »
just keep an eye ( or hand, back thereof ) on them
wheels do get hot, my vectras are hot to touch every morning  :lipsrsealed:
its been redders of late - as long as you are 100% that your brakes arent seizing on, then i wouldnt worry too much unless they are TOO hot to touch
Offline JamesS
« Reply #9 on: 12 September 2012, 16:31 »
If you caliper is siezed on you will notice that:
a) There is smoke + smell coming from your brake pads/discs when you pull over
b) The paint discolours on the wheel
When I did my conversion and used a second hand Corrado brake master cylinder there was obviously a blockage, replaced it with a new G60 one and problem solved!!
Likely that you are ragging it!
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
