Author Topic: Front wheels getting hot.  (Read 2506 times)
Offline Mr Blue
Re: Front wheels getting hot.
« Reply #10 on: 12 September 2012, 17:39 »
You can also fit 239 gti disks and pads. (Vented)
Check the caliper pistons and the caliper sliders. They can seize. Take the sliders out, clean/polish them up, some copper grease and they should slide nicely.
The heat wont do them any good and the sliders may be cause of the problem.
Offline stainesy
« Reply #11 on: 12 September 2012, 18:48 »
If the calipers were sticking wouldn't I have trouble spinning the front wheels freely when jacked up?
They spin fine when front of car is jacked up.
Offline Diamond Hell
  • Opinions я Us
« Reply #12 on: 12 September 2012, 19:48 »
I wouldn't bother.
ONLY use the copper grease well away from the disc though!
This is likely - they get rusty which is when the pads stick.  Expect to find uneven wear front/back pads.
Personally I think you're just getting a lot of brake heat, as the 239s are prone to over-heating, because they are SH*T.
