Author Topic: Mk1 Cab Fuel problems helpppppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1  (Read 1568 times)
Offline bens_Cab
Hi all
heres the problem 87 golf gti cab changed filler neck and petrol tank at begining of the year due to running problems and a noisey fuel pump this sorted out the running problem but not the noisey fuel pump
just changed the fuel pump with another one which was good from a mk1 hard top but it still whines like its struggling to get fuel
ANY IDEAS ?
could it be the accumilator ????
could it be air getting in the system ???
please please help!!!!!!!!!!!!!!!!!!!!!
also just changed the fuel pump and there was loads of black particals in the fuel
Offline dj g
  • vw gals
i have same kind of thing happening
fuel pump leaking :angry:
no accumulattor fitted :huh:
incorrect fuel prrssure regulator fitted :shocked:
main fuel lines damaged insecure and rubbing on steering rack :huh:
steel fuel pipe rubbing on axle and starting to leak :cry:
incorrect fuel pipes fitted around pump :angry:
fuel leaks around injectors :sad:
injector pipes to metering head leaks :undecided:
can you catch your hat i found all this out because car is now cutting out when getting hot
Offline bens_Cab
your having more fun than me my problem is that i dont know if my fuel pump should be running all the time???
Offline mk1
Does the cab have a lift pump :undecided:, is so check that is OK.
Steve.
Offline mk1
Oh, and the injection pump should only run for a short time when the key is first switched on and run constantly when the engine is running.
Steve.
Offline bens_Cab
right this is where im at changed the fuel pump relay now the pump kicks in on ignition but runs constantly when started should it ? now for the good bit i the seems to be starved of fuel when reving over 3500 could it be fuel pressure loss causing the pump to whine and the engine to miss and fart about
also took acumilator of yesterday and blew it out with an airline this is when it started running like pooh could i have damaged it by using an air line to do this ???
Offline bens_Cab
right what a day broke down outside german and sweedish kinda handy got fuel pump got accumilator and lift pump all my problems sorted out in 1 hit car is like a rocket now
heres 1 for fuel pump relay 62 there are two different types of 62 if you have the 1 with the white base where the pins are its wrong its for a mk2 you need the 1 with the brown bottom this 1 primes the pump on ignition
