Author Topic: Will a six speed gearbox from a leon fit in to my mk4 GTI Turbo 2000 AGU  (Read 1522 times)
Offline Neg-1989
  • 1.8t agu stag 1map forge v008 www.derbydubs.co.uk
Hi Dubbers, need a bit of help from all you in the know! Been offered a six speed box from a Leon code on the box is ERR29061.
My Golf is a mk4, 2000 W reg Gti turbo with AGU.
Any help/info would be awesome thanks everyone!
Offline Prawny
  • R-tech power!!!
it will fit yes mate, but you'll also need the driveshafts from the leon, as well as the shifter and cables from inside the car, the left hand engine mount from the 02M gearbox, the 6 speed clutch and flywheel, and a clutch slave cylinder as they're internal on the 02M and external on the o2J.
lot of work but it'll go if it's what you want. if you've got a leon to rob all the parts from it's not too bad.
Offline Neg-1989
thanks prawny you have saved me a lot of bother there bit to much work for the gains
Offline Prawny
  • R-tech power!!!
There are arguably no gains at all!
I much prefer my 5 speed for high speed work, and the 5th and 6th gears are very similar anyway, so no real cruising advantage.
Offline beppe2672
Let me know how you get on with this, had to sell my Edition 30 and downgrade to a mk4 gti, after a month I'm still trying to shift into the 6th gear I dont have! Seriously considering doing this to mine.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline Prawny
  • R-tech power!!!
Don't do it man!
These cars are better on a 5 speed for sure!
Better to stick with the 5spd set up.
Offline rockmonkey69
The fifth gear in the 02j is near as makes no difference as long as the 6th gear in the 02m
The only reason why some upgrade is because the 02m is inherently a stronger box partly because of the larger clutch, flywheel and diff size. Unless your lunching gearboxes with big power I wouldn't bother.
