Author Topic: brakes question?  (Read 9741 times)
Offline gazareth
Re: brakes question?
« Reply #30 on: 02 July 2013, 21:53 »
your brakes are only as good as the tyre it has to stop turning.
Offline Screech16v
  • MK3 20vt AGU
« Reply #31 on: 02 July 2013, 23:19 »
Well not really, repeated heavy use of brakes sh!t tyres or not can still leave you with no brakes.
Offline gazareth
« Reply #32 on: 02 July 2013, 23:32 »
ah you mean if they fade. I just meant if you hit your brakes in an emergency and they lock up and car skids onwards. all depends what the cars going to be used for.
Offline Screech16v
  • MK3 20vt AGU
« Reply #33 on: 02 July 2013, 23:34 »
You should have said  :wink:
Offline gazareth
« Reply #34 on: 02 July 2013, 23:43 »
yeah i suppose so but i thought you would have figured it out.  :wink: but to get fade during normal driving you would really need to be doing something sinister :evil:
Offline Len
« Reply #35 on: 03 July 2013, 12:37 »
You dont lock up with ABS! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline mark-mk3gti
« Reply #36 on: 03 July 2013, 13:46 »
Offline hobbiniho
« Reply #37 on: 03 July 2013, 19:15 »
^^ easiet way is to check what calipers you have if you have LUCAS or GIRLING calipers then you have 280mm brakes and if you have ATE calipers you have 288mm brakes
Cheers for that, confuses the issue more for me, and in theory disreputes the quote i copied, they were Lucas calipers, but when I measured they were 288 but as I said that's going over the centre of the disc, I'm gonna get some vernier calipers on em so I'm def sure when I buy em.. :)
if its lucas calipers they are definately 280mm and you have just said  that when you measured them you had the tape bent over  the disc so it will read bigger than that the disk actually is
Offline mark-mk3gti
« Reply #38 on: 03 July 2013, 19:51 »
I agree, but it was in the high 290s and it only bowed a small amount so basically, im gonna get some vernier calipers on em, cos if I go by your method they are 280 and if I go off the fact its a 96'on and the abs ecu location in the engine bay they are 288, so wheel off again at weekend.. :)
thanks all :)
Offline tweed
« Reply #39 on: 03 July 2013, 20:02 »
Just take a pic and show us.
288mm have a thing metal pad spring.
280mm has nothing.
Easy to tell difference just by looking at them
