Author Topic: brakes question?  (Read 9700 times)
Offline wheatobear
brakes question?
« on: 03 September 2012, 23:04 »
im wanting some new brakes... i got a gti 8v ...
1st.. what size brakes do i have now?
2nd .. what size can i go up to without much mods?
sorry about the n00b questions!
Offline Bellend
Re: brakes question?
« Reply #1 on: 04 September 2012, 00:05 »
What year is it?
Pre 1996 had 280mm brakes later 1996 onwards had 288mm brakes. Pretty much the biggest brakes you can fit under standard 15" alloys.
You can go 312mm brakes just about on some 16" wheels.
288mm brakes are good but tbh standard GTI brakes with a DECENT set of discs and pads are all you're gonna need on a standard car. Couple it with a decent fluid flush through, decent fluid and freeing up the calipers a bit and you'll be fine.
I found the 288mm brakes absolutely spot on with VW discs and pads, really braked well.
Where all my moneys went.
Offline wheatobear
« Reply #2 on: 04 October 2012, 19:38 »
ordered some brake discs and they asked me what car and they sent me 295mm discs...random
Gavv8
« Reply #3 on: 04 October 2012, 19:59 »
The standard setup is more than enough on an 8v, with everything in good condition and nice clean fluid you'll be hard pushed to cause any fade issues.
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 04 October 2012, 22:11 »
What year is it?
280mm is mid 95 (and M platers can have either! but to check lift the rear seat up and if the abs ecu is located there then you have the 280mm)
Offline wheatobear
« Reply #5 on: 05 October 2012, 12:05 »
mine is an N reg...
Offline miggs2002
  • http://i42.photobucket.com/albums/e308/dubster16v/
« Reply #6 on: 05 October 2012, 13:35 »
some EBC redstuff/green stuff pads, using either stock discs or grooved discs, fluid change and some braided pipes you will think you have fitted porsche brakes to it
if you use ATE super blue fluid you can be sure it's all bled through the system, then when you change it again (30k or so) use ATE 200 gold then again you will know when you have hit fresh fluid, as the name suggests they are different coloured fluids
« Last Edit: 05 October 2012, 13:40 by miggs2002 »
Offline wheatobear
« Reply #7 on: 17 October 2012, 15:56 »
Well i ordered 288mm discs and there bigger than the discs i have on now so for some reason my golf hasnt got 288s on??
Offline tweed
« Reply #8 on: 17 October 2012, 18:35 »
Well you answered your own question. Yours is n reg and up to mid 95 golfs came with 280mm as said.
Pre 96 had 280mm as said!
Why you then ordered 288mm is beyond me. You asked a question, got a answer and then ordered the wrong part.  :laugh:
Bit of advise. Only use places/sites that take your reg number to find the correct parts.
Offline leigh_harty
  • Audi AGU
« Reply #9 on: 17 October 2012, 19:13 »
Not always correct. I went into the demontweaks shop in Wrexham and reg number came up with both options. I told him the smaller 280mm set up and he wanted me to identify my set up from a picture of the brake pad... like I'm supposed to know this  :grin:
But on the whole you are correct  :smiley:
Dont lose your dinosaur!
