Author Topic: gear linkage service  (Read 8893 times)
Offline spic gti
« on: 01 September 2012, 18:35 »
just replaced all rubber bushes etc etc  on my mk1 gti 88 cab ,all went well untill i wanted to select a gear!!!! no reverse and some forward , got to be something daft ive done or not done? can any one help ?
Offline raferackstraw
Re: gear linkage service
« Reply #1 on: 01 September 2012, 19:56 »
first off replacing just the rubbers is pointless, you need to get the full refurb kit which is about 25 odd pieces and includes the shaft bush, new ball joint, new link bars and the plastic bushes. you need to replace all parts and then adjust the the gear using the guide on mk1oc forums
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline spic gti
« Reply #2 on: 01 September 2012, 20:09 »
cheers mate i did actually change everything ! i was just lazy on last post
thanks anyway
« Reply #3 on: 01 September 2012, 21:51 »
oh ok mate read the set up guide it involves using a cassette case to get the correct gap at the bottom of the gear lever, which most probably now you have renewed every thing, is whats causing the problem
Offline spic gti
« Reply #4 on: 01 September 2012, 23:01 »
ok mate will do thanks again
Offline Phil Miller
« Reply #5 on: 01 September 2012, 23:12 »
ive got a little metal plate (bought off ebay for £6) what you do is slacken off the rod where it comes thro the bulkhead, this plate holds the gear stick in the correct location so all you do is tighten up the 13mm selector bolt and you will have a perfect gear change, if you want i can lend you the plate, also do you have a wieghted selector rod? if you dont ive got a spare and by fitting that as well makes it spot on perfect
Offline spic gti
« Reply #6 on: 02 September 2012, 19:57 »
thanks mate  but ive sorted it! had 2 probs 1st gear stick in wrong position 2nd had to adjust part which connects to gearbox , not sure name of part but now sorted, after a bit of stress!!! lol
thankyou very much anyway (now onto steering issues).
Offline Guy
« Reply #7 on: 04 September 2012, 17:48 »
can thoroughly recommend the weighted selector rod... i'm not sure if Soundillusion has one on his current car?
Offline JamesW
« Reply #8 on: 09 October 2012, 15:51 »
Where can you get the weighted rods from?
Offline Guy
« Reply #9 on: 10 October 2012, 19:20 »
mk3's  :wink:
