Author Topic: Humbly asking for advice on brakes and suspension  (Read 6022 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Humbly asking for advice on brakes and suspension
« Reply #20 on: 30 August 2012, 21:31 »
i have some 312mm brake set up for sale as it happens  :smiley:
a definite worthy mod
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline F17BAD
« Reply #21 on: 30 August 2012, 21:33 »
I think early 16vs may have been 280s. Not sure though.
ALL early 8, 16 and VR6 only had 280s
Offline Ess_Three
« Reply #22 on: 30 August 2012, 21:33 »
Even with my standard 288mm discs there isn't really that much clearance on my 16'' BBS RX wheels. Once the 312mm's go on they'll be bloody close!
Don't worry...they fit!  :grin:
..but gaining motorcycles.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #23 on: 30 August 2012, 21:34 »
Sadly we don't have lathes in our workshop so isn't going to be happening anytime soon, many a broken throttle body in the process so Ive heard though as the tolerances are so close?
I'm glad you've posted that image actually as it's reminded me to ask, whats the purpose of the smaller vacuum outlet that runs down to the side of the airbox? I know the larger one runs to the purge valve which I've blocked up as it's now been removed.
Offline Ess_Three
« Reply #24 on: 30 August 2012, 21:37 »
It goes to the flap within the airbox that opens on high vacuum to let hot air in.
I binned the flap, sealed the airbox and removed all the tubing...hence blocking up the small take off.
« Reply #25 on: 30 August 2012, 21:38 »
Don't suppose you've got so spare carriers going cheap have you mate?  :wink:
« Reply #26 on: 30 August 2012, 21:42 »
Ah right, i did wonder whether i should bin that as well as the box was gutted of everything yonks ago and i riveted a plate over the hot air inlet. On the side of the air box there are two tiny vacuum inlets, one pipe went with all the gubbins but i was unsure about the one that lead to the throttle body hence it was left in place. Il be scrapping that tomorrow then, cheers.
Offline Dan_GTi8v
« Reply #27 on: 30 August 2012, 21:56 »
how much better if anything is fitting 312 standard brakes over performance 288 eg black diamond?>
