Author Topic: Exhaust Rattle  (Read 3679 times)
Offline GolfGL
Exhaust Rattle
« on: 29 August 2012, 18:24 »
Hi, So i have done some searching before you all ask but i need some clarification, My exhaust is vibrating at certain engine speeds and sounds like crap.
I have checked the heatshields that cover the floor and they are no where near the exhaust and all secure
Its possibly the cat internally or resonance from some where else but it looks in good condition so i suspect not.
Im also suspecting the headers but do the headers have a heatshield and how is it attached - is it bolts or can it be welded. Is this the part i could put a big jubilee round and tighten up, and where should i attach at the base where the cat bolts on or further up as its pretty tight back there?
Thanks for any advice
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Exhaust Rattle
« Reply #1 on: 29 August 2012, 18:32 »
A common easy problem is that a stone could be trapped in between the short crossmember at the rear of the cat. Always worth a check.
Offline DfsGTI
Re: Exhaust Rattle
« Reply #2 on: 29 August 2012, 18:33 »
Heatshield on the downpipe. Mines rattled at 2500rpm
that was the problem
Offline dieselgeezer
Re: Exhaust Rattle
« Reply #3 on: 29 August 2012, 18:42 »
Mine was the downpipe heatshield as well. Got a small G clamp on it & left this in place. Just wondering..do you really need a heatshield?
Offline GolfGL
Re: Exhaust Rattle
« Reply #4 on: 29 August 2012, 19:01 »
The cross member has been off loads for the gear linkage and new exhaust. any solutions on the heatshield dieselgeezer
Offline Screech16v
  • MK3 20vt AGU
Re: Exhaust Rattle
« Reply #5 on: 29 August 2012, 19:40 »
Get the jubilee and put it on the bottom of the downpipe heat shield .
Offline Gti_Jamo
Re: Exhaust Rattle
« Reply #6 on: 30 August 2012, 18:55 »
I removed my heatsheild and heat wrapped the downpipes. Common issue as the metal is so thin.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Exhaust Rattle
« Reply #7 on: 31 August 2012, 14:23 »
Did you remove the heatshield in situ or with the downpipe disconnected?
Offline Gti_Jamo
Re: Exhaust Rattle
« Reply #8 on: 31 August 2012, 14:56 »
Aye it was all disconnected when i did it.
Re: Exhaust Rattle
« Reply #9 on: 31 August 2012, 15:06 »
Piece of piss like that then.
