Author Topic: Rear locking easily  (Read 5157 times)
Offline Khare
  • The bear that khares
Rear locking easily
« on: 29 August 2012, 11:32 »
I've got no ABS in my car, hate the thing so I disabled it. However my rears lock up far before the fronts, causing the rear to step out under heavy braking. As the Mk3's haven't got a brake compensator valve, how can I turn the bias towards the front? Is there any way?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Rear locking easily
« Reply #1 on: 29 August 2012, 11:44 »
I'm sure I've read that the bias valve is part of the ABS system hence why you've now this issue. I'm guessing an inline manually adjusted  bias valve would resolve it though.
« Reply #2 on: 29 August 2012, 11:46 »
IIRC lower spec and early GTIs had rear brake compensators.
Offline Khare
« Reply #3 on: 29 August 2012, 12:32 »
They did. Mine is 1995 though. No valve. I know a manual bias valve would sort it, but don't they require the brake lines to run through the cabin so you can have the valve at hand?
Offline Len
« Reply #4 on: 29 August 2012, 12:41 »
Just a thought but I assume you have checked sticky calipers etc.
www.sas.org.uk
www.the-ace.org.uk
Offline SoundillusioN
« Reply #5 on: 29 August 2012, 12:45 »
No need to run it through the car, just set it up right...  Would probably be easier to get an early spec compensator fitted and set that up correctly.  Or just put your ABS back on.
Offline Khare
« Reply #6 on: 29 August 2012, 12:46 »
Think one side is sticking a tad at the rear. From what I've been reading though the rear will always lock up first as the system is designed to work with ABS. Sucks.
Rather get a valve and adjust it to my liking. Think it's something I'm going to just stick with really, can't be chucking more money at the car!
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 29 August 2012, 14:32 »
well id be carefull. as it happened to me driving my mates 16v with the abs not working and on a straight i had to break heavily and the car stepped out but luckily i caught it back and avoided a c*nt who pulled infront of me. (was scary)
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Khare
« Reply #8 on: 29 August 2012, 14:37 »
Don't worry, I'm used to rear braking only  :wink:
Different on a track mind you.
Offline tshirt2k
  • Been there...Done that...
« Reply #9 on: 29 August 2012, 14:49 »
Switching off your ABS has caused the biasing to be disabled. Very dangerous.
Mk3 ABF 16VT Megasquirt V3
