Author Topic: Rear locking easily  (Read 5136 times)
Offline Ess_Three
Re: Rear locking easily
« Reply #10 on: 29 August 2012, 15:49 »
Switching off your ABS has caused the biasing to be disabled. Very dangerous.
Correct!
Why not just run with ABS?
Why anyone thinks they can brake better without it amazes me.
Isn't it an MOT fail now too?
..but gaining motorcycles.
Offline Khare
  • The bear that khares
« Reply #11 on: 29 August 2012, 16:55 »
Correct!
I just think ABS kicks in too early. I don't like it at all.
Offline twotwofour
« Reply #12 on: 29 August 2012, 16:55 »
Mght be a stupid question but have you just disconnected the abs sensors to disable the abs?
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline Khare
« Reply #13 on: 29 August 2012, 17:05 »
Well...No, the ABS stopped functioning (broken plug).
Offline tweed
« Reply #14 on: 29 August 2012, 18:22 »
I had this problem in my 16v
What I did to over come this was get sh!t standardish pads on the rear that work from cold but fade when hot and the opposite on the front pads.
I just took it easy on the brakes untill I warmed them up and then once hot the fronts would lock first  :wink:
Offline Khare
« Reply #15 on: 29 August 2012, 18:58 »
I've got 288 discs and mintex 1144 pads at front and standard discs and oem spec mintex pads at the rear, so it's more or less that. Would like a bias valve.....Been looking at them on ebay and they're reasonably priced. Only problem is where to fit it and making the joints. I don't have any brake pipe flaring kits or experience either.
Offline tshirt2k
  • Been there...Done that...
« Reply #16 on: 29 August 2012, 20:26 »
Correct!
Maybe you need better tyres or suspension with more travel. Never had a problem with abs coming in too early.
Mk3 ABF 16VT Megasquirt V3
Offline Khare
« Reply #17 on: 29 August 2012, 20:33 »
Use T1R on the front and rainsport 2's on the back, although will get more T1R's when the rainsport's wear.
« Reply #18 on: 29 August 2012, 20:42 »
Better to fix / switch the ABS back on tbh.
« Last Edit: 29 August 2012, 21:36 by Wayne »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #19 on: 29 August 2012, 21:20 »
I must admit  the ABS on my 16v has always been overly sensitive, especially when the brakes are still cold although the rear has never locked up. I just assumed (and hoped) it was down to crappy pads.
