Author Topic: Mk4 golf 1.8t turbo questions  (Read 3329 times)
Offline Chris_smith201055
« on: 29 August 2012, 10:29 »
Hi i have v reg mk4 golf on my logbook it say registered in the year 2000.
Would this mean it already has the ko3s turbo fitted as standard.
Would be greatful if any one could help
As i'm new to mk4 golfs
Offline jamie1989
Re: Mk4 golf 1.8t turbo questions
« Reply #1 on: 29 August 2012, 10:33 »
Take engine cover off on the left hand side of the engine near the inlet mani youl see a 3 digit engine code.
Your looking for either AGU, AUM, ARZ or AUQ.
AGU and ARZ have K03
AUM and AUQ have k03s.  :wink:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline GTi_James
« Reply #2 on: 29 August 2012, 10:41 »
plus 1 for the AUM! though no end of troubles  :cry:
« Reply #3 on: 29 August 2012, 13:21 »
I see its agu.i have a manual boost controler on it and it pulls quit hard on full boost if i was to get a ko3s turbo would it make much difference?
Offline GTi_James
« Reply #4 on: 29 August 2012, 13:33 »
KO3s as i understand is better as handles more but im still a bit wet behind the ears on that  :undecided: im sure it is better tho
Offline jamie1989
« Reply #5 on: 29 August 2012, 13:48 »
First thing is to remove the manual boost controller off the car. Put the N75 back on it.
Then remove the little K03 you have replace it with K03s as its a much better turbo
K03 wont go over 200bhp
K03s will be between 210bhp upto 240ishbhp with alot of supporting mods.
The mid range torque on a K03s remapped is amazing!
Offline golfyste
  • Project track car
« Reply #6 on: 29 August 2012, 14:13 »
+1 on what Jamie has said
1.8t's rely on the n75 to control the boost an using a mbc is not the way forward!
The k03s is a much better turbo and a easy upgrade from the k03
Offline Reesy23
« Reply #7 on: 29 August 2012, 14:30 »
You can use both as the N75 is great at controlling part throttle boost and keeping it driveable, and the MBC would help if you were running crazy boost. If you aren't, you don't really need it.
K03s from k03 is a big difference, my mate has just had it done.
« Reply #8 on: 29 August 2012, 15:32 »
Thanks for help i will get ko3s and get standard boost valve.
I bought the car a few weeks ago so i got a few mods i want to do.
Am in the middle of prepping body work ready for paint jazz blue.its got a few small dents on bonet,roof,boot,wings
Should look nice when its done.
I dnt no wether to smooth the bumpers?
Or keep it looking standard.
Offline Granta Gti
« Reply #9 on: 29 August 2012, 15:38 »
Where is the best place to source a nice ko3s? I called up a company today and they said we don't do ko3s as we expect too much from them and then get dissapointed!!  :laugh:
