Author Topic: Popping exhaust and rough idling  (Read 3929 times)
Offline scottishpedro
« on: 25 August 2012, 02:00 »
Hi all
Today I noticed for the first time my 8v GTI was not idling as well as normal.  Also there is a lot of exhaust popping when coasting in gear, way more than usual. This may be a coincidence (as I have never actually had to sit in traffic in the car before) but I drove the car 100 miles today and sat in 2 traffic jams and I felt a bit of heat around the hand brake; it was quite hot underneath the carpet around this area, could this be a sign of the car running rich and the exhaust getting hotter than usual?
I appreciate your help as usual,
Pedro
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Popping exhaust and rough idling
« Reply #1 on: 25 August 2012, 02:20 »
Blue Temp sender??
When idling disconnect the plug and the rev's should drop if not it need replacing...
For More Info Click To See;
Offline X4MGS
  • VAG Parts SNOB!!!
Offline Gambit
« Reply #3 on: 25 August 2012, 09:22 »
Heat under handbrake is normal.
« Reply #5 on: 25 August 2012, 12:30 »
Ok thanks must just have never noticed it
« Reply #6 on: 25 August 2012, 19:15 »
Blue Temp sender??
Just removed the blue temp sender while idling and I can confirm the revs dropped
Any more ideas?
Thanks
Pedro
« Reply #7 on: 26 August 2012, 17:20 »
Had a better look today to check for air leaks and found this which is probably causing the problem?
« Reply #8 on: 30 August 2012, 18:24 »
I changed the gromit that was perished in that picture and all is now sorted.  The car is idling fine, the exhuast has quitened down when idling and backfires when cruising just the right amount now :)
Offline logeyboy
« Reply #9 on: 31 August 2012, 08:37 »
Where did you get the grommet from?
