Author Topic: Help. Golf running like a bag of nails  (Read 8354 times)
Offline Steve_PD
Re: Help. Golf running like a bag of nails
« Reply #10 on: 23 August 2012, 22:23 »
Mine has smoked since the day it got mapped. No boost leaks.
Offline JackM92
« Reply #11 on: 23 August 2012, 22:26 »
Thought they all give out quite a bit of black smoke. Most of my mates tdi's do.
Anyway, Took the maf off then and took it for a quick blast. There is a section of dual carriage way near my house about half a mile long, Entered it at about 40mph and the best i could get out of it was 70mph. I was in 4th and it was crawling up slowly.
I will check in the morning if there is anything loose.
Offline Rhyso
« Reply #12 on: 23 August 2012, 22:31 »
Try cleaning the sh!t out of your egr and inlet manifold  :tongue:  you fitted those pipes yet?
Not if they are running properly. Sounds like it could be a boost leak
Offline Steve_PD
« Reply #13 on: 23 August 2012, 22:35 »
EGR is clean. am not taking off the inlet as I cant be arsed. And no same reason as <<<that.
Next car I buy will not have to be mapped to achieve what I want, it will be prefect out the box....oh Ive heard that before.... :tongue:
Offline JackM92
« Reply #14 on: 24 August 2012, 17:05 »
Went to my local vw specialist whi have got a good name and they fixed the brake pedal switch and there was a slight boost leak which they fixed.
Turns out the real problem is the camshafts, They have quoted me £400 to supply and fit some 130 cams. Does this sound about right? and is there any benefit to 130 cams?
Offline richw911
Offline JackM92
« Reply #16 on: 24 August 2012, 17:39 »
£400 isnt a bad price then.
« Last Edit: 24 August 2012, 17:41 by JackM92 »
Offline Steve_PD
« Reply #17 on: 24 August 2012, 17:44 »
No its not but Id be wanting new followers at least as the 130 ones fail as well!
Offline JackM92
« Reply #18 on: 24 August 2012, 17:45 »
I will have to ring them tomorrow and see whats included.
Will the car with the current spec run a pd150 turbo or will i need more parts? I just though while it was in getting fixed and getting a remap after it might be worth putting the 150 turbo on.
Offline Steve_PD
« Reply #19 on: 24 August 2012, 21:48 »
It will run a 150 turbo no problem. So its the cams on a 115PD have gone then? And to think everyone says its only the PD 150's which suffer from cam failure..... :lipsrsealed:
