Author Topic: Help. Golf running like a bag of nails  (Read 8307 times)
Offline JackM92
« on: 23 August 2012, 20:51 »
I have a 01 PD115 which has the following mods:
130 turbo and injector
Intercooler
EGR delete and 150 intake
Straight through exhaust
The work was carried out by the previous owner and he only had a 115 remap done on it (Mobile service). I have picked the car up tonight and its running rubbish, Doesnt pull like it should and pulls back alot, especially in 4,5 and 6th gear.
What is the problem? Do i need a live map to smooth out the power and tune the engine to the 130 turbo?
There is a light on the dash, Looks like a coiled wire sideways, Looked in the book and it says the glow plug. Could this be causing the problem?
Thanks
« Last Edit: 23 August 2012, 21:00 by richw911 »
Offline richw911
Re: Help. Golf running like a bag of nails
« Reply #1 on: 23 August 2012, 21:04 »
Read this http://www.golfgtiforum.co.uk/index.php?topic=189447.0
Could be a sensor MAF? or boost leak.
Offline JackM92
« Reply #2 on: 23 August 2012, 21:15 »
Thanks.
Apparently the last owner had it on the computer and it came up as brake pedal switch.
Could this be stopping the car from running properly? and how much does it usually cost, needing done asap.
Offline Rhyso
« Reply #3 on: 23 August 2012, 21:22 »
Thanks.
Not normally
You got any smoke coming out of the back??
Offline JackM92
« Reply #4 on: 23 August 2012, 21:23 »
Yeah just the usual cloud of black smoke. Nothing un-normal.
Offline Rhyso
« Reply #5 on: 23 August 2012, 21:25 »
Urm thats not usual.  You should get a little under load but that should clear through the rev range
Is the car spluttering??
Id say boost leak or maf sensor
Offline JackM92
« Reply #6 on: 23 August 2012, 21:27 »
Yeah juddering a lot when I get over 2k really.
Feels like its got a load of flat spot through out the turbo, Hence why i thought of a remap. It will be completely dead then burst in to life for a second then dead again etc.
Offline Rhyso
« Reply #7 on: 23 August 2012, 21:41 »
Get your head under the bonnet and follow the boost pipes and look for anything obvious like a pipe hanging off
Also disconnect the MAF and see if it drives any better
Offline JackM92
« Reply #8 on: 23 August 2012, 22:06 »
I will have a look in the morning.
NOt sure how to disconnect the MAF, Il have a search and find out.
Thanks
Offline Agreeable Slick
  • Unit
« Reply #9 on: 23 August 2012, 22:08 »
:grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin:
Black smoke = definite boost leak somewhere along the lines.
