Author Topic: lower strut brace  (Read 3671 times)
Offline GTi_James
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: lower strut brace
« Reply #1 on: 23 August 2012, 16:16 »
Offline GTi_James
« Reply #2 on: 23 August 2012, 16:26 »
Don't reckon much at all of those, how about...
http://www.ebay.co.uk/itm/Ultra-Racing-Front-Lower-Brace-Bar-Volkswagen-Golf-Mk4-4-Point-LA4-1271-/140802701468
indeedy i do have them saved for a later buy  :wink:
im a bit stumped though, heres what i want to set up, JOM coilovers with Audi A3/TT pair of shock strut top mount with x2 bearings, an S3 ARB though am tempted with the R32 one though not sure if it would fit, and 4x15mm spacers all round ready for next srping when all the crappy snow and weather goes and i can get my shiny new alloys fitted  :grin:
however the drop links are these
http://www.ebay.co.uk/itm/350586838520?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
but the guys selling them has said hes not sure
"Hi not sure about the S3 arb. If it loops under the prop shaft it wont work if above same as original then they might. I can only suggest you fit the ARB and see what length of drop link you need. The MK4 ones are Adjustable from 119mm to 155mm measured from Pivot center to pivot center Thanks Les"
 :huh:
Offline golfyste
  • Project track car
« Reply #3 on: 23 August 2012, 16:26 »
You have posted Exactly the same link twice mate.
They are a bit like a Audi s3 lower strut brace so quite good.
A anti roll bar is totally different, sits on too of the sub frame and connects your two wishbones.
Offline GTi_James
« Reply #4 on: 23 August 2012, 16:29 »
oops went a bit squint eye'd
http://www.ebay.co.uk/itm/OMP-FRONT-LOWER-RED-STRUT-BRACE-VW-GOLF-MK4-1-8-TURBO-/180939012069?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a20ce37e5
Offline golfyste
  • Project track car
« Reply #5 on: 23 August 2012, 16:29 »
S3 and r32 arb will fit with adjustable drop links but you have to modify them and make them shorter.
Offline GTi_James
« Reply #6 on: 23 August 2012, 16:30 »
so fitting a strut and ARB is overkill or a rollercoaster for corners?
Offline golfyste
  • Project track car
« Reply #7 on: 23 August 2012, 16:31 »
I wouldn't say you can have overkill  :laugh:
Just make sure you get a nice big rear arb to balance it out but it will handle much better  :smiley:
Offline GTi_James
« Reply #8 on: 23 August 2012, 16:37 »
got any part numbers for RARB? cant find anything on ebay apart from an R32 one but the guys said it wont fit a GTi, but if im fitting drop links it should fit right?  :undecided:
Offline Golf_GT_TDI
« Reply #9 on: 23 August 2012, 16:38 »
The OMP you've just linked to would be much better I'm sure with it being steel over the cheapo alumiunum ones
