Author Topic: Can you get leaky water pumps ??? :(  (Read 2870 times)
Offline Jimmyrallye
  • 20vt goodness
« on: 20 August 2012, 20:04 »
Evening guys ive had a mystery coolant leak for a few weeks .. Only seemed to go down when car had been driven .. Well earliar i had the engine running for good hour and noticed a litte drip comeing from waterpump !!! (great) :( can these fail or seals go inside them ? Is it a difficult job to do any one done one before ?  Do i need to replace cambelt ? Ate they run on same belt ?Thanks jimmy :)
« Last Edit: 20 August 2012, 20:26 by Jimmyrallye »
Offline Gambit
Re: Can you get leaky water pumps ??? :(
« Reply #1 on: 20 August 2012, 20:59 »
Yes thats tell tale sign of water pump starting to fail
not too bad a job to change though seeing as it driven using aux belt and not timing belt. Couple of hours to replace. Try to buy a complete pump and not just a new impeller side
Offline Jimmyrallye
  • 20vt goodness
« Reply #2 on: 20 August 2012, 21:12 »
Thanks gambit just watched a few videos of it dosent seem a bad job ... Euro car parts do a couple of full pumps onr at £37.50 and the other at £45 will order one of those up :)
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 20 August 2012, 21:39 »
If you dont have one buy one of those hose clip grip tools...
makes the job so much easier...
Also get a tube of sealer....
For More Info Click To See;
Offline X4MGS
  • VAG Parts SNOB!!!
Offline Jimmyrallye
  • 20vt goodness
« Reply #5 on: 20 August 2012, 21:57 »
Thanks i can borrow one of those of my friend... Like you said there a nightmare to undo them clips with grips/mole grips
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #6 on: 21 August 2012, 11:30 »
Be very careful when refitting the water pump. Make sure the o-ring is seated correctly, and slowly offer up the pump to the block.
Hold the pump firmly - don't let it slip - as you tighten the bolts, as even the slightest movement of the o-ring from it's seat will result in a leak, and a deformed o-ring.
This is what I found when replacing my water pump.
 :angry:
Offline Jimmyrallye
  • 20vt goodness
« Reply #7 on: 21 August 2012, 12:05 »
Cheers dude has been noted ;)
Offline blueseamonkey
« Reply #8 on: 27 August 2012, 00:31 »
Careful with the bolts too, especially if you've got aircon fitted. The double ended bolts holding the pump and compressor are almost a tenner each.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 27 August 2012, 00:33 »
99.9% of UK cars don't have Air Con unfortunately... It's one thing I would like to fit... But I don't hold out much chance of getting one....
