Author Topic: Can you get leaky water pumps ??? :(  (Read 2871 times)
Offline prasina2
Re: Can you get leaky water pumps ??? :(
« Reply #10 on: 27 August 2012, 01:08 »
Another thing to check before installing a new pump is the housing bolts. I've received new pumps and found the the bolts for the housing were loose. Just check that they're tight before installing the pump.
Happich latch replacement linkages for MK1/Mk2 pop-out windows, CNC aluminum...PM for details
Offline Jimmyrallye
  • 20vt goodness
« Reply #11 on: 27 August 2012, 09:41 »
Thanks for all the replys guys ;) fitted new waterpump but still looseing coolant :( ive had enough of this engine now!!! Just put a deposit down on new engine will update when complete
