Author Topic: Recomend me a tripod  (Read 2790 times)
Offline Toby
  • Car - less
« on: 20 August 2012, 18:35 »
not to expencive, not to cheap.
Any recomendations!
Currently down under
Offline Luke1981
Re: Recomend me a tripod
« Reply #1 on: 20 August 2012, 20:03 »
I have a Velbon tripod which has served me well. Plenty on ebay and not to expensive!
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Toby
  • Car - less
« Reply #2 on: 20 August 2012, 20:17 »
Not to  bad price wise!!
Watching a few!
Offline T_J_G
« Reply #3 on: 20 August 2012, 21:05 »
Red snapper
Offline shepgti
« Reply #4 on: 20 August 2012, 22:37 »
Have a look on mpb photographic. They have second hand stuff that is decent, i bought a manfrotto tripod plus manfrotto ball head for 90 quid new they are over 200.
Offline Ridg
  • TDI - Soot Happens!
« Reply #5 on: 21 August 2012, 10:18 »
I have a Manfrotto 055XPROB with the following heads;
808RC4 (3 way)
496RC2 (Ballhead)
303SPH (Multi-row pano)
If you've only going to buy one head then a ball head is probably the best bet, very flexible but generally doesn't off the precision / fine tuning of a 3 way
You should be able to find deals on the Manfrotto + head deals.
Redsnapper are a very good value alternative
Have a read through http://www.bythom.com/support.htm and consider if it's worth paying the extra for something that you can grow with.
Offline Guy
« Reply #6 on: 21 August 2012, 10:30 »
i have the same manfrotto tripod as ridg but with a ball head only... its a very good and very sturdy tripod... if a little heavy
i wish i had gone for the carbon fibre option
Offline DubFan
« Reply #7 on: 21 August 2012, 13:42 »
Offline Ridg
« Reply #8 on: 21 August 2012, 15:58 »
If your budget is a bit smaller, you could go for a compact Manfrotto for £40:
http://www.amazon.co.uk/Manfrotto-MKC3-P02-Compact-Photo-Kit/dp/B0049SVU26/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=IFHX74AZZXGB&coliid=I52L9LEHXMKHS
with a weight limit of 1.5Kg you're limited to entry level bodies and the smaller lenses so depends what you're shooting with.
Offline stealthwolf
« Reply #9 on: 21 August 2012, 17:49 »
I bought a similar one (H01 instead of P02) as a spur-of-the-moment purchase from Argos (was supposed to buy one in advance but forgot).
Positives: very light - feels lighter than my G12 camera; portable - can shove it in my backpack; easy to se up and use - takes seconds to set up; comfort - the handle is comfortable
Negatives: the ball joint means it's impossible to get the camera absolutely level; it's not easy to keep the camera horizontal when panning
If it simply had a couple of spirit levels built in, I'd have been happy. I'm looking at buying one of those spirit-level cubes that fit into the hotshoe of the camera.
